Модели автомобили => Rio => Темата е започната от: CoolMaN® в Юли 13, 2012, 04:09:05 pm
Сервизни бюлетини KIA Rio (UB) - 2012
(списъкът ще се актуализира когато се появи нов бюлетин в системата на KIA)
Само за България:
7/6/2012, General, KGE12-92-P210 - Introduction of new service procedure for Mobis Audio (http://dl.dropbox.com/u/105816300/Rio/TSB/38033.pdf)
7/6/2012, General, KGE12-10-P140 - 41th LABOR TIME STANDARDS UPDATE (http://dl.dropbox.com/u/105816300/Rio/TSB/38031.pdf)
7/6/2012, Field Fix, KFE12-14-E180 - ECM UPGRADE - UB 1.2 AUTO CRUISE CONTROL LOGIC IMPROVEMENT (http://dl.dropbox.com/u/105816300/Rio/TSB/38030.pdf)
7/6/2012, General, KGE12-12-P150 - U-ENGINE WATER PUMP AND MOUNTING BOLT CHANGE (http://dl.dropbox.com/u/105816300/Rio/TSB/38028.pdf)
7/6/2012, General, KGE12-10-P120 - 40th LABOR TIME STANDARDS UPDATE (http://dl.dropbox.com/u/105816300/Rio/TSB/38026.pdf)
7/6/2012, General, KGE12-52-P031 - (REVISED) 4-SPEED A/T (A4CF0/1/2) VALVE BODY CHANGE (http://dl.dropbox.com/u/105816300/Rio/TSB/38019.pdf)
7/6/2012, General, KGE12-52-P021 - (REVISED) 6-SPEED A/T VALVE BODY ACCUMULATOR PISTON AND COIL SPRING CHANGE (http://dl.dropbox.com/u/105816300/Rio/TSB/38018.pdf)
7/6/2012, General, KGE12-52-P030 - KGE12-52-P030 REVISED SEE KGE12-52-P031 (http://dl.dropbox.com/u/105816300/Rio/TSB/38014.pdf)
7/6/2012, General, KGE12-52-P020 - KGE12-52-P020 REVISED SEE KGE12-52-P021 (http://dl.dropbox.com/u/105816300/Rio/TSB/38013.pdf)
7/6/2012, Field Fix, KFE12-51-P030 - CLUTCH DISC AND COVER ASSEMBLY REPLACEMENT (http://dl.dropbox.com/u/105816300/Rio/TSB/38008.pdf)
7/6/2012, General, KGE11-13-P011 - (REVISED) A/U DIESEL ENGINE EGR VALVE BODY SERVICE KIT (http://dl.dropbox.com/u/105816300/Rio/TSB/38007.pdf)
7/6/2012, General, KGE12-10-P090 - 39th LABOR TIME STANDARDS UPDATE (http://dl.dropbox.com/u/105816300/Rio/TSB/38006.pdf)
5/23/2012, General, KGE12-92-P140 - NOTICE OF AVN REGULAR SOFTWARE UPGRADE (http://dl.dropbox.com/u/105816300/Rio/TSB/37184.pdf)
5/3/2012, General, KGE12-52-P031 - (REVISED) 4-SPEED A/T (A4CF0/1/2) VALVE BODY CHANGE (http://dl.dropbox.com/u/105816300/Rio/TSB/36817.pdf)
5/3/2012, General, KGE12-52-P021 - (REVISED) 6-SPEED A/T VALVE BODY ACCUMULATOR PISTON AND COIL SPRING CHANGE (http://dl.dropbox.com/u/105816300/Rio/TSB/36816.pdf)
4/11/2012, General, KGE12-10-P070 - 38th LABOR TIME STANDARDS UPDATE (http://dl.dropbox.com/u/105816300/Rio/TSB/36316.pdf)
4/11/2012, General, KGE12-61-P030 - ASSEMBLY & DISASSEMBLY PROCEDURES OF EPS GEAR BOX ASSEMBLY (http://dl.dropbox.com/u/105816300/Rio/TSB/36313.pdf)
3/7/2012, General, KGE11-10-P420 - 35th LABOR TIME STANDARDS UPDATE (http://dl.dropbox.com/u/105816300/Rio/TSB/35706.pdf)
3/7/2012, General, KGE12-91-P030 - NOTIFICATION ON NEW PAINT COLOR CODES FOR 2012MY RIO (UB/QBr) (http://dl.dropbox.com/u/105816300/Rio/TSB/35695.pdf)
3/7/2012, General, KGE12-10-P020 - 36th LABOR TIME STANDARDS UPDATE (http://dl.dropbox.com/u/105816300/Rio/TSB/35693.pdf)
3/7/2012, General, KGE12-12-P070 - SERVICE PRECAUTIONS - ENGINE OIL FILTER REPLACEMENT ON U- ENGINE (http://dl.dropbox.com/u/105816300/Rio/TSB/35666.pdf)
3/7/2012, Service Action, KCE11-11-P241 - (REVISED) BATTERY CABLE TERMINAL REPLACEMENT (http://dl.dropbox.com/u/105816300/Rio/TSB/35664.pdf)
3/7/2012, General, KGE12-10-P050 - 37th LABOR TIME STANDARDS UPDATE (http://dl.dropbox.com/u/105816300/Rio/TSB/35663.pdf)
3/7/2012, Field Fix, KFE11-92-P720 - HEAD LAMP MOISTURE INSPECTION AND DEFOGGING PROCEDURE (http://dl.dropbox.com/u/105816300/Rio/TSB/35658.pdf)
2/23/2012, Service Action, KCE11-11-P240 - KCE11-11-P240 REVISED SEE KCE11-11-P241: BATTERY CABLE TERMINAL REPLACEMENT (http://dl.dropbox.com/u/105816300/Rio/TSB/35328.pdf)
2/23/2012, Service Action, KCE11-61-P080 - STEERING WHEEL SPRING WASHER REPLACEMENT (http://dl.dropbox.com/u/105816300/Rio/TSB/35327.pdf)
2/23/2012, Service Action, KCE11-11-P241 - (REVISED) BATTERY CABLE TERMINAL REPLACEMENT (http://dl.dropbox.com/u/105816300/Rio/TSB/35322.pdf)
11/28/2011, General, KGE11-92-P700 - SERVICE REMINDER FOR POWER WINDOW REGULATOR MOTOR INITIALIZATION (http://dl.dropbox.com/u/105816300/Rio/TSB/33264.pdf)
Извън България:
10/5/2012, Field Fix, KFE12-91-P370 - CONSOLE BOX FLOOR INSULATION PAD ADDITIONAL INSTALLATION (http://dl.dropbox.com/u/105816300/Rio/TSB/39679.pdf)
10/11/2012, Field Fix, KFE12-14-E320 - UB U1.4 DPF & OIL LEVEL SENSOR LOGIC IMPROVEMENT (http://dl.dropbox.com/u/105816300/Rio/TSB/39707.pdf)
8/29/2012, Field Fix, KFE12-14-E221 - ECM UPGRADE - Type UB 1.4 ACCELERATION IMPROVEMENT (http://dl.dropbox.com/u/105816300/Rio/TSB/38985.pdf)
8/23/2012, Service Action, KCE12-51-P140 - INSPECTION ON HARD SHIFTING FROM NEUTRAL GEAR TO REVERSE GEAR AND M/T REPLACEMENT (http://dl.dropbox.com/u/105816300/Rio/TSB/38869.pdf)
8/20/2012, Field Fix, KFE12-14-E290 - ECM UPGRADE - UB 1.4L KNOCKING IMPROVEMENT (http://dl.dropbox.com/u/105816300/Rio/TSB/38644.pdf)
8/3/2012, Customer Satisfaction, KCE12-51-P090 - 6-SPEED MANUAL TRANSMISSION (M6CF3-1) CASE INSPECTION AND REPLACEMENT (http://dl.dropbox.com/u/105816300/Rio/TSB/38350.pdf)
7/27/2012, Field Fix, KFE12-14-E280 - ECM&FATC UPGRADE - ECM&A/CON CONTROL UNIT UPGRRADE (http://dl.dropbox.com/u/105816300/Rio/TSB/38354.pdf)
7/24/2012, Field Fix, KFE12-51-P030 - CLUTCH DISC AND COVER ASSEMBLY REPLACEMENT (http://dl.dropbox.com/u/105816300/Rio/TSB/38275.pdf)
7/23/2012, Field Fix, KFE12-61-E010 - ECM UPGRADE - UB EPS ECU UPDATE (http://dl.dropbox.com/u/105816300/Rio/TSB/38261.pdf)
7/9/2012, Field Fix, KFE11-92-P720 - HEAD LAMP MOISTURE INSPECTION AND DEFOGGING PROCEDURE (http://dl.dropbox.com/u/105816300/Rio/TSB/38063.pdf)
Само за САЩ:
December 2011, 086, RIO (UB) INSTRUMENT PANEL PAD NOISE REPAIR (https://dl.dropbox.com/u/105816300/Rio/TSB/086us.pdf)
