Автор Тема: Продавам car audio ,Alpine,JBL,Pioneer,Ground Zero,Clarion.  (Прочетена 5761 пъти)
AGT
« -: Септември 20, 2009, 06:38:02 pm »
Продавам следните car audio компоненти:
Clarion APA2104 two channel power amplifier – 140лв.
APA2104 main features:
    Continuous power output (2x50W 4ohms)
    Continuous power output bridged (1x125W)
    Stable down to 1ohm loads
    Bridgeable for mono-drive (1x100W)
    Variable low-pass filter (50 - 200 Hz)
    Variable high-pass filter (40 -200 Hz)
    Variable frequency bass extender (30 - 120Hz)
    Input gain control (200mV - 5V)
    2ohm load capability in stereo drive
    Protection circuits for overheating and speaker lead short-circuit
CD / MP3 Player Pioneer  DEH-P40MP
Перфектно състояние в кашон (2_ра употреба) 1бр.- 160лв
Specifications
Main features
                                         DEH-P40MP
Max. Power Output                                    MOSFET 50W x 4
Tuner                                                            AM/FM
Plays                                                            CD-R, CD-RW, MP3, WMA, WAV
Front Panel                                            Removable
Display Illumination                                   Blue-back LCD
Button Illumination                                   Red
Remote Control                                           Included
Cellular Telephone Auto Muting                   Yes
Connectivity                                           DEH-P40MP
Aux-in                                                   Rear
IP Bus                                                   Yes
RCA Preout                                            2 (F+R or S/W)
Sub-display Output                                   Yes
Hard-wired Remote Input                           Yes
Direct Sub Drive                                           Yes
ISO Connector ready                                   Yes
Full Control Expansion Units                           Multi-CD, TV, iPod
Partial Control Expansion Units                   Multi-DVD, DAB, USB, Bluetooth
Tuner Features                                           DEH-P40MP
Radio Data System (RDS)                           Yes
Traffic Announcement                                   Yes
Best Stations Memory (BSM)                           Yes
Auto Alternative Frequency Search                   Yes
Preset Channel Memory                                    18
Auto/Manual Frequency Search                   Yes
PTY Search   Yes
CD Player Features                                   DEH-P40MP
CD-R/RW Playback                                   Yes
MP3                                                           Yes
WAV                                                     Yes
Windows Media Audio (WMA)                           Yes
CD Text                                                   Yes
MP3 Text Display                                           Yes
Disc Title Memory                                           Yes
Track Search/Scan/Repeat                           Yes/Yes/Yes
Last Position Memory                                   Yes
Random Play                                           Yes
Audio                                                           DEH-P40MP
Balance                                                   Yes
Fader                                                           Yes
Bass, Mid, Treble                                           Yes
Low Pass Filter                                           Yes
High Pass Filter                                           Yes
Parametric Equaliser                                   3-band
Front Image Enhancer                                    Yes
Source Level Adjuster (SLA)                            Yes
BMX                                                            Yes
Attenuator                                                    Yes
JBL: GTO-4000 Amplifier – 170лв.
Product Features:
•   4/3/2 channel amplifier
•   4 x 50w RMS or tri-mode: 2 x 50W RMS + 150W for sub
•   4 x 100W max or tri-mode: 2 x 100W + 300W for sub
•   Variable cross-over. Variable Bass Boost.
•   Overload protection
JBL GTO4060 - 170лв
Illuminated JBL® Logo — Looks simply cool.
Silverbrushed All-Aluminum Heatsink — This heatsink runs all around the amp and ensures efficient heat dissipation.
Variable Crossover Networks — Integrated HP and LP filters allow you to tune the amp's output to the characteristics of nearly every speaker.
Bass EQ Circuit (+6dB @ 45Hz) —Fine-tune the bass output depending on personal taste.
Variable Input Sensitivity (100mV—4V) — For compatibility with all head units.
Effective Protection Circuitry — Protects against short circuits, overheating and overcurrent.
High-Quality Power, Input and Output Connectors — For clean, tight, long-lasting connections.
   SPECIFICATIONS
General
Type   4-/3-/2-Channel Amplifier
Power Output   55 Watts RMS x 4 channels at 4 ohms
and ≤1% THD+N
75 watts RMS x 4 channels at 2 ohms and ≤1% THD+N
150 watts RMS x 2 channels at 4 ohms,
14.4V supply and ≤1% THD+N
Signal-to-Noise Ratio   80dBA (reference 1 watt into 4 ohms)
Dynamic Power   100W at 2 ohms
Effective Damping Factor   6.354 at 4 ohms
Frequency Response (-3dB)   10Hz — 100kHz
Maximum input signal   4V
Maximum Sensitivity   100mV
Output Regulation   0.07dB at 4 ohms
Dimensions (H x W x D)   358x294x55mm (14-1/8"x11-9/16"x2-3/16")
JBL GTO 4000  --- чисто нови --- 210лв
4/3/2 Channel 600W Car Audio Amplifier
• JBL GTO4000 600W Amp
• 4/3/2 Channel Amplifier
JBL GTO 75.2   ЧИСТО НОВ   --- 250лв.
o The GTO 75.2 high-output MOSFET power supply ensures optimum power delivery into numerous impedances with low distortion.
o The 75.2 comes outfitted with a variable 12dB per octave electronic crossover allowing you to optimize system tuning based on speaker location and accompanying loudspeaker components.
o Full range preamp outputs are provided facilitating multiple amplifier hookups without the need for high-loss Y-adapters or signal splitters.
Specifications
• 97 Watts RMS x 2 channels at 4 ohms and ≤ 1% THD + N
• Signal-to-noise ratio: 82dBA (reference 1 watt into 4 ohms)
• 145 Watts RMS x 2 channels at 2 ohms, 14.4V supply and ≤ 1% THD + N
• 290 Watts RMS x 1 channel at 4 ohms, 14.4V supply and ≤ 1% THD + N
• Dynamic power: 190 watts at 2 ohms
• Effective damping factor: 6.39 at 4 ohms
• Frequency response: 10Hz - 90kHz (-3dB)
• Maximum input signal: 5.5V
• Maximum sensitivity: 230mV
• Output regulation: .098dB at 4 ohms
• 12dB Built-in, variable, low-pass electronic crossover
• One pair full-range preamp outputs
• Separate high-level and low-level inputs
• Dimensions (L x W x H): 295mm x 313mm x 60mm
GROUND ZERO GZIA 4100 HP  - ЧИСТО НОВИ – 200лв.
Power RMS 4ohm (Stereo): 4x65w
Power RMS 2ohm (Stereo): 4x100w
Power RMS 4ohm (Bridged): 1x210w
Damping factor:> 70 (1 KHZ at 4OHM)
Signal to noise ratio:>80 DB (Reference 1 W output)
Frequency response:10 HZ- 30KHZ
Input Sensitivty: 0.2 - 6v
Alpine MRV-1000 --- 250лв.
RMS power at 12V 20Hz-20kHz
2 x 100W @ 4 ohms (0.08% THD)
2 x 200W @ 2 ohms (0.3% THD)
1 x 400W @ 4 ohms bridge (0.3% THD)
Dynamic power at 14.4V 20Hz-20kHz
2 x 150W @ 4 ohms (0.08% THD)
2 x 300W @ 2 ohms (0.3% THD)
1 x 600W @ 4 ohms bridge (0.3% THD)
Fuse: 2 x 30A
JBL GTO 75.2   - 150лв  2_ра употреба ..........налични 2 броя.
Specifications
Някой от цените подлежат на разумен коментар при сериозен интерес  :)  Всички неща се намират и могат да бъдат видяни в Пловдив.За други градове по куриер ( ЕКОНТ ) с наложен платеж. Транспорта е за сметка на клиента.
Телефон 0888 757399 Аврам.
